92 dodge dynasty poured out anti freeze
Old 05-21-03, 08:59 PM
madbass
Unhappy 92 dodge dynasty poured out anti freeze
I have a 92 dodge dynasty with a 3.3L v-6 engine. there was a grinding sound comming from the belt area I wasnt sure what it was then, I seen that one of the wheels was shaking as if it was loose. I took it for a drive, about 5 miles andnoise got louder. When I returned home ther was antifreeze pouring out from behind the wheel. could you tell what caused the loose wheel and why did antifreeze pourout from behind it? I have an automatic transmission.
Old 05-21-03, 10:35 PM
B
sounds like the waterpump has failed, suggest not driving till fixed. as for what caused it normal wear and tear likely.
Old 05-22-03, 02:22 AM
msargent's Avatar
I assume when you say "wheel" you mean pully that the belt rides on? I'd agree with bejay.. Sounds like a water pump, and engine damage can occur if the car is continued to be driven before it's fixed.
Old 05-22-03, 03:52 AM
Joe_F
I agree.
