U-Joints
Old 05-22-03, 05:35 AM
Hirsch's Avatar
U-Joints
I had a 90 Dodge Dakota. Just yarded it because i lunched the transmission, due to driveshaft popping out due to a bad U-joint. Would lubrication have cured the problem U-joint when it started to make noise and vibrate? This is for future reference. Thank you for any answers. Have a good one!!
Old 05-22-03, 05:52 AM
mikejmerritt
Hello Hirsch, greasing may have bought you a day or two once a vibration set in but the basic answer to your question is no....Mike
Old 05-22-03, 06:45 AM
Hirsch's Avatar
Thank you much!!! It made me wonder
Old 05-22-03, 07:24 AM
Joe_F
If the U-joints were bad, they require replacement.
Old 05-22-03, 08:50 AM
msargent's Avatar
I agree.. Keep in mind though, most OE u-joints now aren't greasable anyways..Replacement ones usually are..And if you're going to replace 1, replace them all at the same time..
