Ford rear end lube
Ford rear end lube
1993 Ford F150, 5.0 Ltr, 4WD, 187,000 miles. there does not apear to be a drain plug on the rear end differential. I know that some models were made this way, so I'm just checking. there is a plug on the front side of the differential about midway from bottom to top, on the drivers side of the drive shaft. Is that the filler plug, and if so, is that the level to which you fill the unit with fresh fluid?
