autobmobile repair
Old 05-30-03, 12:45 PM
beckyann mills
autobmobile repair
replacing the front brakes (hopefully pads only) on a front-wheel drive 1998 honda civic.
How hard is this....do I get involved with the front wheel drive part?
Old 05-30-03, 03:37 PM
the_tow_guy's Avatar
Go here:
http://www.cybrrpartspro.com/Manual%...delLookup.html
and you should find the procedure. That new a car should be no reason to do anything other than replace the pads, UNLESS they have worn to the point of damageing the rotors. Don't recall how Hondas are mounted, but normally couple of bolts and the calpier assembly comes free of its mounting. Compress pistons back into caliper using large c-clamp or special tool (check local parts store for loaner tools), install new pads, reinstall caliper. Do one side at a time, so that you can use the one that is not apart for reference if you forget how something goes back together.
And SAFETY FIRST; make sure vehicle is properly supported on solid ground with jack stands.
Old 05-30-03, 03:43 PM
Just checked the auto library link and apparently they don't have the Honda info. You'll need to pick up a Chilton or Haynes manual for the car or subscribe to alldata on line for the info.
Old 05-30-03, 03:58 PM
Joe_F
I agree. If the rotors are scored, pitch 'em. It will cost you 20 bucks to get them cut and they STILL may be warped. That 20 bucks should go to new ones
