Replacing Struts
Old 06-02-03, 04:28 PM
Praisenhm
Replacing Struts
Can anyone tell me how to replace the rear struts on a 1999 Plymouth Voyager? Is it easy enough to do on my own?
Thanks
Old 06-02-03, 11:10 PM
knuckles
Old 06-03-03, 06:48 AM
Joe_F
You'll need a good assortment of hand tools. Air tools make the job a LOT easier.
Old 06-03-03, 07:22 PM
jason1b
the only problem you are going to run into is you need to compress the spring onto the strut,you can buy a tool to do that but the shop near by will do it for you cheaper,so my suggetion is to remove the old struts then take the springs and the new struts to a shop,have them compress the springs onto the strut,the will probably only charge you $10.00-$20.00 and the toll costs atlests $40.00
Old 06-03-03, 10:57 PM
knuckles
Arrow
The '99 Caravan (both the FWD and AWD models) use leaf springs and conventional shock absorbers in the rear. No special tools are needed for this job.
