1987 pontiac Bonn.key broke off in switch
Old 06-04-03, 05:50 PM
Question 1987 pontiac Bonn.key broke off in switch
Hi; My 1987 pontiac bonn. has a key broken off in the ignition switch. I need to remove the switch how do I do that? I have the steering wheel off, but there is a lot of stuff in there.Will the switch just pull out some how?Got to be a trick about getting it out.
thanks mike ray
Old 06-04-03, 11:02 PM
knuckles
There's no trick per se, but you'll need a lock plate depressor in order to get at the lock cylinder. You can buy or rent one from Autozone or most any other parts store.
Click on the link below for lock cylinder R&R info.
http://www.cybrrpartspro.com/Manual%...delLookup.html
Old 06-05-03, 04:13 AM
Joe_F
I agree. Most times when I'm in there I change the turn signal switch because you have to "fold" it over in order to get at the lock cylinder. Sometimes the wires get brittle with age.
