95 mercury villager fuel relay switch
Teebow's Avatar
06-06-03, 04:49 PM   #1
Teebow
I put in a new fuel pump, but there is no sound or action, I was told to check the fuel relay switch......how?
Joe_F's Avatar
06-07-03, 06:46 AM   #2
Joe_F
By obtaining a wiring diagram through Autolibrary.org below, Alldata.com ($25.00) or a Ford factory manual.
Follow the diagnostic procedures in each. The fuel pump may not have been the problem, always check parts before pitching them first!
msargent's Avatar
06-07-03, 12:09 PM   #3
Sounds like what they MIGHT have been saying is, "Check the inertia switch and the fuel pump relay"...
Inertia switch on a mini van is usually behind 1 of the kick panels,
and the fuel pump relay is in the main fuse box under the hood..
Either 1 of these can kill voltage to the fuel pump..
As for actually testing them, follow Joe's advice and get a decent manual..It should also give component locations...
