no pedal
Old 06-09-03, 08:57 AM
dragonl2ep
Question no pedal
I have a 1994 saturn sl sedan that has no brake pedal checked brakes all good no leaks. replaced master cyl and bled to specifications still no pedal. adjusted rears still no pedal. does not have abs. oh sorry it is a 1.9l dohc any help is apreciated
Old 06-09-03, 09:44 AM
Joe_F
You did bench bleed the master, right?
Old 06-09-03, 10:40 AM
dragonl2ep
i did bench bleed the master cyl LOL also i blocked off rear hoses and pedal still went down then i blocked off the fronts and pedal was very hard wouldnt move.
Old 06-09-03, 10:58 AM
Caliper slide hanging? Block off each front to isolate which side it is.
Larry
Old 06-09-03, 02:50 PM
dragonl2ep
thank you very much for the input both of the upper sliders were rusted solid fixed problem
Old 06-09-03, 02:54 PM
Joe_F
Thumbs up
Good call by Larry.
