Transmission leaking
rmartin's Avatar
06-12-03, 06:30 PM   #1
rmartin
My 1992 Ford Ranger XLT w/ 5 speed manual transmission is leaking. It was leaking at the rear tail of the transmission. I called Fod Dealer and was told there is no gasket for it, to just use permatex. I did that and it still leaked. I pulled it again/cleaned and made my own gasket which I put in and permatexed on both sides. It still leaks, although not as much. Someone mentioned I should check to see if the vents are plugged. Has anyone anyone out there ever unplugged them? The transmission is a Mazda F17A KB A546035. Anyone have any input? Can't figure out why is is still leaking after all of that. I can't seeme to see why it is still leaking.
Joe_F's Avatar
06-12-03, 06:32 PM   #2
Joe_F
See if Felpro has a seal or gasket for this application. They often have "Problem Solver" parts for known trouble applications.
billys68ss's Avatar
WV
06-13-03, 11:23 AM   #3
Are you absolutely positive that is where it is leaking from? Sounds to me more like a rear seal leaking. I would check that first. Or, worse yet you could have a front seal leaking.
Billy
