A Mitsubishi Moment . . . 3000GT again
Old 06-16-03, 04:01 PM
proton05
Great car except when it stalls in the middle of an intersection. Thanks for the reply. I did not know I could take the MAF it into a parts store for a check. Could you tell me if the Mass Air Flow Meter can be installed easily (I have the new one). On the face, it looks simple (hahaha). A general question about codes: My check engine light only goes on when it's going to stall and once it's done the breakdown thing and it finally starts again . . . the light goes back off. If the part is replaced do codes STILL need to be erased? THANKS FOR ANY REPLIES! Those Mitsubishi Moments!
Old 06-16-03, 04:35 PM
Joe_F
Use the reply button instead of posting a new post each time...otherwise continuity is lost.
As stated, pick up a $25 Alldata.com subscription---will have all you need if autolibrary.org below doesn't have it.
These 3000GTs/Dodge Stealths are far from stellar cars. Very cheap quality, very problem ridden and expensive to upkeep in the long haul.
