turn signals on 95 grand am
The left turn signal doesn't always work. the light will stay on and not blink, or not come on at all. When I turn on the hazard lights the right front signals don't come on at all. Can I fix this or should I take it to a mechanic?
Thanks,
sven
Thanks,
sven
check all the bulbs both front and back not just turn signals, but brake lights and park lights tail lights replace any that are defective, if you still have a problem you will likely want to get it fixed at a shop.
usually when the indicator stays on and does not flash it is due to a bad bulb. and it is easy enough to check just have someone run all the lights for you, while you check for ones that are not working.
