turn signals on 95 grand am
Old 06-17-03, 06:08 PM
sven556
The left turn signal doesn't always work. the light will stay on and not blink, or not come on at all. When I turn on the hazard lights the right front signals don't come on at all. Can I fix this or should I take it to a mechanic?
Thanks,
sven
Old 06-17-03, 06:47 PM
B
check all the bulbs both front and back not just turn signals, but brake lights and park lights tail lights replace any that are defective, if you still have a problem you will likely want to get it fixed at a shop.
usually when the indicator stays on and does not flash it is due to a bad bulb. and it is easy enough to check just have someone run all the lights for you, while you check for ones that are not working.
Old 06-17-03, 09:11 PM
Joe_F
Correct.
