98 Buick Century, Locks and Windows
Old 06-18-03, 11:07 AM
tkays
'98 Buick Century 4 door
Several problems, not sure if they are related or not.
Power Locks - Just went out the other day. The keychain remote will not work. Nor will the power lock switch on the driver door to lock all dors
Rear Driver side door- Will not lock unless you manually lock it from the inside. Even when the keychain remote and driver door switch worked.
**Also, the window will not roll down with either the front driver switch or the rear door switch.
Driver side power window- Will sometimes roll down (seems like when I first start the car it will roll down and up for a while, but later on will not)
other 2 windows on passenger side work fine
Old 06-18-03, 01:39 PM
Check the wires in the door jam when you open it. Peel back the rubber boot and see if the wires are broken. Check both sides.
Old 06-18-03, 03:00 PM
Joe_F
I agree.
Old 06-18-03, 06:02 PM
darrell McCoy
On the windows: Bear in mind that buick had a lot of window motor problems for about 5 years. Put 3 in same 96 buick in 4 years.
Old 06-18-03, 08:18 PM
C
SSSHHhhh! Don't let my 96 GS hear you! It's starting to
have gremlins in the window motors too!
Christopher
Old 06-19-03, 10:15 AM
tkays
If it is the wires, what is my next step?
Old 06-19-03, 12:46 PM
Joe_F
Using an OEM wiring diagram to guide you, check each affected wire carefully for breaks in the insulation, rubbing, grounding, etc.
