transmission problem
Old 06-21-03, 08:51 PM
thexcabby
i have a 1993 pontiac grand am quad 4. auto trans refuses to drop into any forward or reverse gear.fuses are all good, shifting linkage is working.tried unplugging tork senser, no results, tranny fluid is dark brownish red, but not burnt ..is there any thing else i can try before i get out my 30 06 rifle out to lay it to rest?
Old 06-21-03, 09:08 PM
sounds like you can get out your rifle or get another transmission put in it.
Old 06-21-03, 09:13 PM
Joe_F
I agree, sounds wasted .
Coupling with the fact that the Quad 4 is a loser of an engine (head gasket failures), you might be money ahead pitching this one and putting the green into something better.
Old 06-22-03, 06:35 AM
Not to argue but alot of quad 4s got headgaskets when the oil vapor separator was clogged,which is a big part of the pcv system on those engines.Or the separator hoses collapsed.On the trans you most likely need a new one because the input clutch or the input sprag clutch are more than likely cooked.
Old 06-23-03, 03:54 PM
One other thing are the bolts that hold the converter to the flywheel still there?
