Front brakes on Ford Explorer
Old 06-22-03, 09:50 AM
petebrandon
Question Front brakes on Ford Explorer
1998 Ford Explorer, 4.0 SOHC engine, 4 wheel drive, automatic transmission. I need to replace the front brake rotors. I can remove the caliper, but not the caliper bracket. How do I remove the rotor? I have new rotors--they do not have hubs. Are these press-on rotors? Please tell me how to remove and replace the front rotors. Thanks
Old 06-22-03, 10:00 AM
darrell McCoy
check Joe's basics. There are detailed instructions on this.
Old 06-22-03, 10:05 AM
billys68ss's Avatar
The rotors on this vehicle should come right off. It may take some persuasion(with a hammer) and there may be a screw that holds it in place. There should be 2 bolts on the back of the caliper bracket that once you remove them you will be able to get the rotor off.
Billy
Old 06-22-03, 10:54 AM
Joe_F
See autolibrary.org below.
