replacing a starter
Old 06-23-03, 03:41 PM
bde33
replacing a starter
I have a 1988 Ford F150 Lariat Pickup with an automatic transmission. I am convinced that the started is going bad because the battery checks out. It starts early in the morning on the way to work, but if I try to start it within the next couple of hours after arriving at work, it will not start. However. If I wait until late in the evening, it will start. My theory is that the starter will not work when it is hot. What I need to know is whether a novice mechanic like me can fairly easily change the starter on this truck. Any instructions on the how-to would be appreciated.
Old 06-23-03, 04:19 PM
89blaze's Avatar
http://www.cybrrpartspro.com/Manual%...delLookup.html Check this out, you have a very easy job ahead of you.
Old 06-23-03, 05:15 PM
Joe_F
Check the condition of your cables and connections first.
Then, as 89Blazer stated.
Trackbacks are On
Pingbacks are On
Refbacks are On
