transmission codes?????
Old 06-26-03, 11:49 AM
AKADA1
i have a 96 ford tuarus and when i had the car in they did a diognostics on my car and it came out with codes: po761, po741,and po734. what do these codes mean? any info would be great!!!!
Old 06-26-03, 04:23 PM
Joe_F
Trouble . This transmission is very failure prone, and those are common Ford codes which come up on this.
Check alldata.com for technical service bulletin titles on the codes/problem descriptions, and have a Ford dealer print out the full copies of the bulletins.
Old 06-26-03, 05:28 PM
billys68ss's Avatar
Here is the description of the codes.
P0761
SAE Standard --Shift Solenoid "C" Performance or Stuck Off
Probable Cause --Wiring, Shift solenoid (SS) "C", Engine Control Module or Transmission Control Module
P0741
SAE Standard --Torque Converter Clutch Circuit Performance or Stuck Off
Probable Cause --Transmission Fluide level, Torque Converter Clutch, Torque Converter Clutch solenoid, Transmission Fault, Engine Control Module or Transmission Control Module
P0734
SAE Standard --Gear no. 4 Incorrect Ratio
Probable Cause --Trans Fluid level, Transmission Fault, Engine Control Module or Transmission Control Module
Looks to me like you have a computer problem. All 3 codes lead to that.
Hope this helps,
Billy
