98 Toyota Avalon-check engine light
CharlieVee's Avatar
06-29-03, 06:07 PM   #1
CharlieVee
Can anyone give me some code help please? I have a 1998 Toyotal Avalon XLS 3.0 liter V-6 with 105,000 miles on it.
The check engine light is on. The code provided by the dealership when I had the valve cover gasget replaced is PO 135 B1s1. I think it is the O2 sensor but before I replace it (at a cost of about $124.00) I want to know if I am replacing the correct thing.
Thanks for any help!!
's Avatar
06-29-03, 06:42 PM   #2
i haven't worked on a toyota, the codes are standardized industry wide though. 'p0135' means b1s1 oxygen sensor heater failure, it could be a sensor or it could be a wire feeding it or it could be the computer, only a properly done test will determine what it is. b1s1 can only mean one place 'bank1' and upstream(before catalytic converter), bank1 is always the same bank of cylinders(3) that have cylinder #1, so, find spark plug #1, follow that side exhaust manifold to the sensor(before cat) , after the cat it b1s2.
hope that helps
's Avatar
06-29-03, 06:48 PM   #3
also, the check engine light should stay on until the computer retests the system, could take up to three 'trips' each manufacturer determines what a 'trip' consists of and how many times it must pass the test to turn the light off, sometimes unplugging the battery might work, again, depends on the manufacturer
toyotaman11769's Avatar
06-29-03, 07:45 PM   #4
Good info by mike:
It's the sensor in the manifold next to the firewall, usually just failure of the sensor.
Larry
's Avatar
06-29-03, 08:26 PM   #5
yeah, i know, i've replaced a bunch of sensors for this, only once did i have a heater failure code for all four sensors, it was 'only' a fuse that was blown(by a rubbed through harness)
i just didn't want him coming back saying he replaced it and now the dealer said he needs a computer or something like that
CharlieVee's Avatar
06-29-03, 08:42 PM   #6
CharlieVee
Thanks guys. I'll get to work on it and let you know what I come up with.
Joe_F's Avatar
06-30-03, 04:21 AM   #7
Joe_F
All posters are correct. At the mileage you have, the 02 sensor replacement would make sense.
