battery warning light stays on after I put new battery in the car 1990 olds
Old 06-30-03, 10:33 AM
buddy
Angry battery warning light stays on after I put new battery in the car 1990 olds
I have a 1990 olds car and when I put the new battery in the battery warning light will not go off do I have a short somewhere.
because the car sounds like it needs more battery power. And where do I look for a short.
Old 06-30-03, 11:05 AM
C
Re: battery warning light stays on after I put new battery in the car 1990 olds
Do you have access to a voltmeter? If so, what's the voltage
at the battery terminals with and without the car running? You
might have something as simple as a bad alternator. Those
new style GM alternators aren't well put together and they
have issues with high heat. I went through a couple in Florida,
and there was nothing my rebuilder could do except redo
the work.
Christopher
Old 06-30-03, 11:12 AM
Joe_F
As noted, likely a bad alternator. Replace with a Delco rebuilt.
Old 06-30-03, 05:04 PM
msargent's Avatar
Please don't forget to check fuses and fusable links.. Also make sure the battery is fully charged when replacing an alternator..A weak battery has killed many a new alternator..
Old 06-30-03, 05:21 PM
msargent's Avatar
Old 07-02-03, 02:10 PM
Naugghtydawg
simular problem
i had a simular problem after installing a new battery and volts looked good -- pulled off alternator took to oriely and had it checked and the diode was bad most places can check alternators for you
