92 bonney ignition
Old 07-01-03, 11:09 PM
jimster
92 bonney ignition
hi
i have 92 bonneville ssei and i recently had to remove ignition because of jammed key, so i remove and replace
actually my friend remove and i dont know where two wires on end of cylender connect and i cannot ask friend because he out of country. can someone please tell me where wires connect
Old 07-02-03, 04:38 AM
Joe_F
What color are the wires? Possibly for the antitheft system.
Old 07-02-03, 06:12 PM
jimster
yes i think for antitheft system. wires are orange and white. but i cant find where wires connect
Old 07-02-03, 09:17 PM
if it is for the antitheft system they usually run down the column with the turnsignal switch wiring and plug in at the base of the column, if there is no connector there may be a bulk connector that the terminals lock into along with your turn signal switch wiring, usually the new cylinder comes with a dummy key and is only good for cutting purposes you will still have to get the correct coded key for your car cut to the dummy key that came with the new cylinder.
