car air conditioner
Old 07-04-03, 12:20 PM
borninjapan
car air conditioner
When putting freon in a car, should it be running or off. Should the readings from the compressor be with the car off or on.
Old 07-04-03, 12:29 PM
msargent's Avatar
It really depends on the servicing equipment you're using. The machine I use at work allows me to add freon to a car either way..If servicing an empty system, I do that with the car off. Once I've added the proper amount, then I run the car to make sure the readings (pressures) are correct, and that the system is cooling properly.. I have worked with some machines that tell you not to service a system with the car running..
Old 07-04-03, 03:30 PM
Joe_F
What type of car and what tools and equipment are you using?
