92 olds ciera cuts out
Old 07-05-03, 08:46 AM
psu1td
I have a 92 olds ciera 3.3 6 cyl that dies after about 5 miles or 15 min running , it just cuts out and all the lights on the dash come on after about 15 min it will start back up again. I took it to a garage and there were no codes in ite memory but they said that it was getting fuel and the crankshaft sensor was ok and that it narrowed it down to the ignition module, I replaced that with a new one but the problem still persist. Any ideas out there what could be wrong.
Old 07-05-03, 01:20 PM
Joe_F
The module installed could be defective as could the coil pack.
Next time it occurs, pull off a spark plug wire, crank it over and see if you have spark.
