new tires need alignment?
michael van's Avatar
TX
07-05-03, 06:49 PM   #1
My son has a 1999 Toyota Corolla he just had new tires installed now he says that the car pulls to the right.
Car did not pull before new tires what do you guys think?
darrell McCoy's Avatar
07-05-03, 07:24 PM   #2
darrell McCoy
Check the tire sizes. Strangely enough I have seen tires installed, 3- the right size and 1 the wrong size. example, 3--215's and 1-205. It happens. Then try front to back rotation and see if the problem is still there. Possible you have a bad tire. Did the old tires wear evenly?
Quick's Avatar
07-05-03, 07:28 PM   #3
Quick
If both front tires were replaced (with the same brand and type of tire hopefully), the first thing to check would be tire air pressure. If both tires have the correct air pressure and it still pulls to one side, you're probably right. A front-end alignment may be needed.
There are a couple of out of the ordinary things that could have occurred like different sized tires causing the tire to rub on something; different tread patterns; one tire larger than the other (anyone can make a mistake), etc. But commonly, if the air pressure is right, the next step is probably an alignment.
TX
07-05-03, 07:42 PM   #4
Will check
I will check the size when he gets home I have not seen the new tires his grandpaw and him went out and bought them while I was on vacation.All 4 tires are new BFG the old tires wear pattren was good except for being underinflated.I have told him how to check pressure.
Thanks I never thought that they might have installed one oddball size but I will check it out and also the pressure.
Joe_F's Avatar
07-05-03, 10:54 PM   #5
Joe_F
Agree with all.
msargent's Avatar
07-06-03, 04:57 AM   #6
Try swapping the front tires from side to side. If the pull of the car changes with the tire swap, you have a bad tire..(assuming there is proper air pressure in both, and their the same size) I've seen this many times over the years..Reguardless, I'd take it back to the shop..If it didn't pull before putting them on, and it doesn't now, I'd ask for another pair...
TX
07-06-03, 08:44 AM   #7
fixed
Went out and checked items size was good pressure was not.
I found front left tire 35 PSI and right front tire 27 PSI I inflated it to 35 PSI and test drove no pulling.Thanks guys for the great tips This fourm is great.
Michael
07-06-03, 08:59 AM   #8
darrell McCoy
Glad that is was a easy fix.
