1998 Explorer Question
Hack's Avatar
07-07-03, 12:06 PM   #1
Hack
I'll try this once more...
Vehicle: 1998 Ford Explorer, 6cyl SOHC, AT, 78000 miles
I am experiencing the following symptoms:
1) Engine runs on the hot side
2) Noticiable loss of power when a/c is running
3) A/C when on max cools intermittently
4) Transmission seems to shift much sooner than normal
5) Significant MPG loss - normally 18/gal and now 14/gal
When engine is cold, vehicle operates fine both with A/C on and off. Once engine warms up I notice the above symptoms especially when A/C is running.
My initial thought was a a loose belt and then I thought of a faulty thermostat but I am not sure a thermostat would cause all of these issues. NOTE: No belt screeching is heard.
I want to take it into the shop but I like to be as specific as possible. Can anybody help diagnosing the problem?
TIA
Hack
Joe_F's Avatar
07-07-03, 12:36 PM   #2
Joe_F
Thermostats can affect emissions due to coolant temperature, sure.
Replace it, flush the cooling system and see where that nets you. Use a Motorcraft/Ford thermostat.
davo's Avatar
07-07-03, 03:36 PM   #3
Perhaps the fan clutch is going bad.
Hack's Avatar
07-08-03, 08:09 PM   #4
Hack
I thought I would report back as to the fix, since I took my car in to the shop today. They replaced the thermostat and did a coolant flush and all is well.
Thanks Joe and Davo for your responses.
Hack
