1996 ford ranger
Old 07-07-03, 12:21 PM
mawmaw
1996 ford ranger
need help with ranger that sat for 10 days in driveway. We had alot of rain but the truck never went thru any water, just sat in driveway. Now when starting the idle is awful, the truck shakes and then stalls. We smell gas. When finally starting we were able to take it down the street but still stalls when stopping. Could it be moisture? Where? thanks.
Old 07-07-03, 12:35 PM
Joe_F
Engine size? Is the check engine light on? Mileage? When's the last time it saw service?
Old 07-07-03, 02:45 PM
mawmaw
service 4mos. ago 96,000 miles 4cyl. everything changed at last service, belts hoses, etc.
Old 07-07-03, 04:44 PM
Joe_F
Pull off the hose on the fuel pressure regulator and see if fuel comes out of it. If so, wasted regulator.
Old 07-08-03, 02:55 PM
mawmaw
Confused over having fuel injection or not
if not, what is it?
Old 07-08-03, 11:58 PM
G
Guest
maybe some moisture condensed inside the dist. cap(if the truck has one), maybe the cap wasn't seated correctly, maybe moisture got on the plug wires, or near the plugs, try drying all parts of the ignition system off if you think it's a problem due to the rain, when it's 100% humidity, moisture gets everywhere!
a totally different car than this i had would leak rain into the computer if i parked it at a certain angle, car would run like crap for a day or two, unless i got mad enough to take it out and dry it with some compressed air
