99' Contour problems
Old 07-07-03, 01:31 PM
I have a 1999 Ford Conour with the 2.0 liter 4-cyl. engine, and an auto transmission. A while back, I had a problem with the car stuttering when you take off from a stop, to the point where it felt as though it was going to die a couple of times. I finally took it into a shop, and they replaced the MAF sensor, and said it was fixed. That was about 2 months ago, and it hasn't happened since. Well, yesterday, after about a half hour of driving, the car suddenly just shut itself off. All the warning lights came on, and the car just died. I was able to restart the car, and then drive it without problems back to the shop where I had it fixed previously. That being said, I have 2 questions:
1) Does anyone think the 2 problems are related?
2) Does anyone have any idea what could have happened?
Any input is appreciated. Thanks
Old 07-07-03, 01:46 PM
Joe_F
Tough to say unless it happens again. Was a Ford MAF used or a used one, aftermarket?
Old 07-07-03, 01:51 PM
I'm almost certain it was a Ford MAF.....
What's weird is I never saw a CEL, even when the stuttering was happening, and even now.
Old 07-07-03, 01:52 PM
Joe_F
May not set the MIL, even with a bad one, usually does though.
Make sure it was a new Ford MAF. Some aftermarket ones vary widely in quality.
Old 07-07-03, 02:20 PM
Would that make the car shut off, though? I would think it would affect performance more than something that can shut the car down.....
Old 07-07-03, 04:50 PM
Joe_F
Sure would, I have seen it happen. I've tapped MAFs with a screwdriver handle and stalled a car . That indicates a bad connection inside.
