1988 buick 3.8 v6 pk. ave stalling out
car started jumping some in OD then got worse now will crank up and wants to stall when u give the gas. have taken coil pack off of module and there is a lot of looks like melted sky blue chewing gum on bottom of coil pac and top of module. anyone had this problem i plant to replace tue. is this goo dangerous. any feed back appreciated.
I doubt the blue goo is dangerous but wash your hands good when your done you will feel better.I v'e never seen this blue goo however and been working on cars 26 years.Maybe someone used blue rtv between them.
hey roger, on that jeep grand cherokee with the a/c drain problem, you can thank 'bejay' for reminding me to check my bulletins, especially tsb#24-06-96, pull back the carpet by the passenger's feet and drill a 1/4" hole into the lowest part of the drain housing(drill parallel with the ground, do not drill straight up) then get a coat hanger and start cleaning, then you need a plug to cap it when you're done
