'89 Corsica brakes
Old 07-08-03, 10:41 AM
markaz
'89 Corsica brakes
Want to change the front pads on '89 Chev Corsica 2.8L myself. Have always had someone else do it. Have the pads, lube, tools, etc. Is there a site I can go to for the step-by-step on this job as the manual is long gone. Thanks
Old 07-08-03, 11:29 AM
Joe_F
Check autolibrary.org below in my signature file.
Old 07-08-03, 12:05 PM
markaz
When I went to http://www.cybrrpartspro.com/Manual%...elLookup.html. I entered the year and model and was directed to a page to identify the engine size. I get the following message. "The information you are looking for is not currently available.
Be certain you are using the correct vehicle identification.
Be sure to use your vehicle MODEL and NOT MAKE
For example: 1995 Escort, NOT 1995 Ford.!" Any other suggestions?
Old 07-08-03, 12:16 PM
Joe_F
1989 Corsica is what you should type. 1989 might be too old for the site, it only goes back so far.
Try 1992 or 1993 Corsica or Beretta. Same basic procedure for all GM front drivers.
Failing that, hit your local library for a manual.
Old 07-08-03, 12:17 PM
markaz
Forget my last post. The site does not recognize the Opera browser and could not get to the proper vehicle when clicking their link. Able to get the info using IE. Thanks for the help.
Old 07-08-03, 12:30 PM
Joe_F
Thumbs up
The instructions are there. Doesn't get any better than that . I just checked.
