02 sensor 1996 grand caravan
Old 07-08-03, 12:29 PM
T
TClyde01
Question 02 sensor 1996 grand caravan
please tell me the best/easiest way to remove sensor then install new one?
Old 07-08-03, 12:31 PM
Joe_F
Using either an open end wrench the correct size (about 19mm) or a socket made for this purpose (Autozone has them or will rent you one) remove it after removing the electrical connector.
Install it snug and plug in the connector again. Done.
Old 07-08-03, 04:58 PM
msargent's Avatar
If your van has a 3.0 liter, sometimes it's easiest to take the air filter box off, and reach over the top of the engine to remove and replace the O2 sensor..If you don't have a "proper" socket, 7/8" combo wrench works just fine...
Old 07-08-03, 11:45 PM
G
Guest
yes, if it's a 3.0L it's best to get the upstream sensor from the top on a COLD engine(minus the airbox), the downstream sensor is obviously easier from the bottom
if it is a (more popular) 3.3 or 3.8L, the only way i know is with an offset 'crowsfoot' looking socket from the bottom, there's no room above the sensor for a conventional socket and it's set into a recess. note: the engine must be ice cold or you will get second and third degree burns as you will be leaning on the catalytic converter to get the upstream out, the downstream is a piece of cake
i haven't replaced one on a 2.4L yet, not very popular, but with the airbox out, i think you can see/replace it from the top (upstream)--- downstream is, as always, easier from the bottom
note2: you will have to drive for a few days until the computer retests the system and it passes two to three times in a row until it will turn the light off, provided you changed the correct sensor
all sensors regardless of engine is a 7/8"
