What's the buzz?
What's the buzz?
1992 Ford Ranger XLT
4.0 litre / 6 cyl.
4 x 4 electric shift<---------- that puppy never worked
170,000 km. (150,000 miles?)
Yesterday, while waiting in the drive-thru at a burger place, a loud buzzing/grinding sound from the front of the vehicle happened about 10 or 11 times.
The sound lasted about 5 seconds each interval.
I felt a vibration under my feet when the buzzing/grinding was going on. As we left the burger place, I accelerated 2 or 3 times and the sound happened again as I stepped on the gas.
By the time I pulled over and had a look under the hood, the sound had stopped. I did notice a slight burning smell for a couple of seconds. Couldn't be sure but I think it had an electrical odor to it.
The only other symptom I could see in the cab was a slightly higher than normal water temperature while all this was going on.
I've posted here about this beast before but just to refresh everyone's memories:
1) I had a rebuilt transmission put in last year. Maybe a questionable job because twice now the pan bolts have magically come loose & leaked most of the fluid. Shifting has been slightly erratic so I took it back twice for band adjustments.
2) As I said earlier, the 4 x 4 worked for a short time but then quit. Replies from you guys here seem to indicate that I have a dead shift motor. As I understand it, this motor is located under the driver's side area. Could it have been making all the racket? Shorting out?
Any other (cheap ;-) possibilities? If I had money or a stick of dynamite, believe me, I would take care of the problem ;-)
4.0 litre / 6 cyl.
Tough to say really without hearing it....keep an eye, or errr ear on it and try to pinpoint it a bit better.
On the 4x4 problem, Knuckles had posted a link to a website where it has the procedure to clean the brushes in the 4WD actuator which may bring the 4WD back to life.
Look it up on the web in google.com. I'm sure there are technical articles on this subject. Try "Cleaning 4WD actuator brushes Ford Truck" or something similar when you search.
Usually when the 4WD isn't used much, the brushes glaze like that.
Is the noise like a groan? Ford power steering pumps tend to be pretty piss poor.
It could be the seat belt buzzer, again tough to say without hearing it myself.
Text doesn't lend itself well to sound. LOL
What type of hubs does your truck have? If they're auto-engaging (meaning locked all the time) then it could be the solenoid that engages the front axles..???
Thanks Sarge :-) (you 2 Joe :-)
It's a place to start looking.. Let us know what you find out!
Original poster:
Try this link for cleaning/servicing the actuator:
http://www.glue.umd.edu/~singletn/web/pages/tcase.html
I think it answers the question of how to clean the actuator
As MSA said, let us know what you find
Previous Thread
Next Thread
