repair to 93 jeep
repair to 93 jeep
I have a 1993 Jeep Sport Cherokree 4.0 Liter Auto trans. The problem I have is sometimes it will not start until I wiggle the shifter around. Some times this work sometimes not. Then I have to wait and try later. Can you please tell me, if you can the problem I should look for and what I need to do to repair this thanks.
Sounds like the neutral safety switch is bad, loose, or out of adjustment.
Located on the side of the transmission, it's easy to replace.
Click on the link below to download the R&R/adjustment procedure.
http://www.batauto.com/techs/93_jeep...ety_switch.zip
