transmission repair
Old 07-14-03, 03:24 PM
coolmo
transmission repair
92geo metro will not stay in fifth gear or (overdrive) keeps jumping out , what needs to be done?
Old 07-14-03, 03:56 PM
Joe_F
Arrow
You either have a clutch or a tranny problem.
If the vehicle hasn't seen a clutch, that's a good hint of the problem. It could also have internal failure of the tranny.
Frankly, it could cost more than the car is worth to fix the tranny---a used one would be all this little shoe is worth .
Old 07-14-03, 05:08 PM
sdsdogg2's Avatar
Could be bad motor mounts or shift linkage bent or worn . Also syncro, shift rail detents or shift fork problem but check the first two first.
