1995 buick skylark cooling system
Old 07-14-03, 07:39 PM
al parrish
Post 1995 buick skylark cooling system
I have a 1995 buick skylark that has a fitting going into the firewall directly under the air conditioning lines. It appears to be a cooling line of some sort that leaks. There was a 90 degree rubber connector on it but I cannot locate any type of line that attaches to it. I am looking for help on what the line/fitting might be and where the line originates. al
Old 07-14-03, 07:56 PM
Joe_F
Helps to know which engine we're talking about.
Hit any GM dealer's parts counter---their parts people's computers will have an illustration and tell you what it is.
Old 07-14-03, 09:08 PM
sounds like the evaporator drain, probably have a leaking heater core if you are leaking antifreeze out of it, should just have water coming out of the drain from condensation from the a/c.
