07-15-03, 10:50 AM
2000 5.9 dakota - stalls in the AM
2000 5.9 dakota - when I start it in the morning, if I put it into gear right away (after the initial high idle - 3-5 seconds), the RPM's drop to almost null, and then they surge to about 1500. Sometimes the RPM's drop enough that I stall out. If I let the truck idle for a good 20-30 seconds before putting it into gear I usually don't have the pblm. . . i know i know. . . if waiting 30 seconds prevents the problem, then problem solved. . .but it didn't do it when I bought in 2001. And it only occurs in the morning - maybe it's not a morning truck :-) - when I leave work in the afternoon, I can start it up, and put it into gear right away.
and also, my girlfriends 91 honda accord has just started doing it.
I throw a bottle of STP injector cleaner in the tank at every oil change (2000-2500 miles).
is this just an idle control pblm?
07-15-03, 11:35 AM
Joe_F
It could be. Did you get gas at the same station?
Any trouble codes? Run by Autozone and have them scan it to be sure.
