'86 Honda Accord: won't start
Old 07-24-03, 01:40 PM
C
Received 25 Upvotes on 22 Posts
1986 Honda Accord hatchback, 100k+ miles, auto trans, carburetor engine.
Our on again, off again Honda is off again: it was running fine, sat for a week or two, then wouldn't crank next time I tried it. No dash lights, no dome light, no horn, nothing. I tried to jump it, but no results. The battery is about a year old. Because I don't get any lights even during the jump process, I wonder if the ground wire's connection has failed...?
Any thoughts? What's the best way to troubleshoot this?
Thanks
Old 07-24-03, 05:30 PM
Joe_F
Check all connections closely for corrosion, tightness and soundness first.
Measure the battery voltage with a digital meter. Tell us what you find.
Old 07-26-03, 07:03 AM
msargent's Avatar
These cars are bad about "burning" up the ignition swithces, and will cause the same results. Work sometimes, then not. Not a very expensive repair, not very hard to check out..
