2000 caviler gas flow problems
Old 07-25-03, 03:12 PM
G
groovydogg
can anyone tell me an easy way to check gas flow? The car will run when I drop a little gas into the carb but it sputters and dies after about 5 seconds or so. There is a noise (hum) coming from where I expect the gas pump is (by the gas tank) but I am expecting that there is no flow. Thanx
Old 07-25-03, 03:35 PM
were do you put the gas
Were do you put the gas on a 2000 model I am sure it is fuel injected.That humm you hear is probbably the fuel pump.Check all your fuses first you might have a fuse blown for the injectors
Old 07-25-03, 04:01 PM
Joe_F
Arrow
Original poster:
Head to Autozone and get a fuel pressure gauge. They will rent you one for free. Tell us what you regulated fuel pressure is.
