volt meter buried at 18
saldog6's Avatar
08-01-03, 09:03 PM   #1
93 lumina, 3.1 L, with volt gauge....my problem is it is buried while car is running at 18+....volt meter off the battery reads 14.4 and is constant.....any type of sensor i can replace that makes it read right? any hints? thanx, Sal....if i use door locks or windows it moves a bit....car in accessory position without running reads fine.....faulty gauge? any help would be great....
Joe_F's Avatar
08-02-03, 04:03 AM   #2
Joe_F
I assume you have done an alternator output test as shown in my "The Basics" below?
If so, likely a wiring or gauge problem.
davo's Avatar
08-03-03, 08:05 AM   #3
Most likely the voltmeter in the dash is faulty.It would be less expensive to add an aftermarket voltmeter.I personally wouldn't worry about it because 14.4 is normal charge rate.
