auto thermostat
Old 08-02-03, 12:29 PM
yurksy
auto thermostat
i pull a boat with a broncoII 1987 with 143000 miles on it and it heats up when i pullup hills in warm weather.Can i run the truck without a thermostat without hurting the motor? thanks
by the way the gaskets on the valve covers went on pretty much OK. Thanks to everyone!!
yurksy
Old 08-02-03, 03:42 PM
autotech156
Sounds like your system needs a good flush. Remove the thermostat, then flush the cooling system, then replace the stat with a new one.
By removing the stat completely, The ECM will not see the temperature it is looking for and try and alter your fuel trims..
Old 08-02-03, 05:57 PM
the_tow_guy's Avatar
Received 39 Votes on 31 Posts
If you don't have one already, you might also install an independent transmission cooler vice using the integral one in the radiator.
Old 08-02-03, 11:57 PM
Guest
a properly functioning thermostat will never 'cause' a car to overheat
a clogged radiator, worn blade on the water pump, low coolant level, an old worn out/loose fins radiator, leaves and mud in front of the radiator, viscous fan not engaging, electric fan not working right, lean fuel mixture, partially clogged cat converter, too heavy a boat for the truck-----all these can lead to an overheat condition
ps. i hope you never put in 'stop leak' before, in the radiator.
Old 08-03-03, 05:49 AM
Joe_F
Thumbs up
All are correct. Find the source of the problem and correct it.
