electric window is stuck in the down position
steve mcp's Avatar
08-02-03, 11:56 AM   #1
steve mcp
hi, i have a 99 saturn sw2 (station wagon),ive been having a problem with the driver door window (electric)...it has been making a ratcheting noise when you operate the window,usually have to assist the window up or down by hand...anyway opened up the door panel to see if i could spot the problem and i rolled the window all the way down and now it wont go back up...help!
darrell McCoy's Avatar
08-02-03, 01:27 PM   #2
darrell McCoy
sounds to me a bad gear/gearhead on the motor.
tazzilla's Avatar
08-02-03, 09:59 PM   #3
tazzilla
Yep I agree I am a ford master tech and that would be the problem.
Joe_F's Avatar
08-03-03, 04:58 AM   #4
Joe_F
Can you hear the motor run? If so, likely a stripped regulator/gear tape as stated here.
