fastidle/stalling
Old 08-03-03, 10:01 AM
U
umpy
fastidle/stalling
85 dodge aries 1.8litre engine.Car starts at high idle even after it is at normal operating temperarture.It is fuel injected.If the idle does kick down and runs rough or stalls.I don't hear any vacume leaks.Once the idle is normal ,if you try to rev up the engine a power loss indicator comes on andit won't take any fuel and the engine stalls.sometimes if you let up on the throttle it will idle a moment then stall. If you restart engine it goes back on fast idle.spark plugs are new fuel filter new,dist. cap and wires look good.I just got the car and don't know much about it's maitenance history. any suggestions?
Old 08-03-03, 04:20 PM
Joe_F
No 1.8L in an Aries....
Go through all the vacuum lines. Have Autozone run the vehicle for codes. Post what they find here.
