Integra automatic transmission grinds
Old 08-05-03, 09:08 PM
My daughterís 1994 Acura Integra RS grinds in position 1 or in 4th gear. The transmission is fine in second or D3 but when it hits 4th or if you put it in 1 it makes a loud grinding noise but no noise in first if itís in D3 or D4. What could cause the noise and why position 1 and 4th.
Old 08-05-03, 09:44 PM
Lightbulb
check the amount of lubricant in the transmission, has any transmission service been done on this car? Be sure to only use Honda Trans Fluid,
OM
Old 08-06-03, 04:39 AM
Joe_F
I agree with OM. How many miles?
Old 08-06-03, 07:16 AM
The car has 180,000 miles. Will the honda fluid really make that much of a difference?
Old 08-06-03, 08:59 AM
Joe_F
Not likely, it sounds like internal failure of the tranny, especially at that mileage.
Some fluids are Honda specific and if you use anything else, it can cause problems. I believe Hondas use Dexron in their automatics though---check your owner's manual to be sure.
Old 08-06-03, 04:41 PM
Generally speaking when a auto trans makes a grinding noise,it's having a hard part failure.Hard parts are not changed on standard rebuilds because they are big money parts.I don't have a Honda range reference chart but something that is applied in 1st and 4th is going south.
