Buick brake job
Old 08-07-03, 07:11 PM
Buick brake job
Hi Folks, was planning on doing the front brakes on my daughters 1994 Buick Century this weekend but I'm not sure what type of bolt holds the calipers on. Does anyone here know for sure. I know some Ford use a large torx and others I've seen have an Allen head bolt. Can't say that I've ever done a GM product before. Is there any special tool I need to buy??
Joe, I know you'll want me to check the cyberparts site so I'll head there after this.
Old 08-07-03, 07:31 PM
Joe_F
T-30ish on those front drivers. Autozone can rent them to you, or they are dirt cheap in sets from Sears and have a lifetime warranty .
Yes, check autolibrary .
Old 08-08-03, 04:54 PM
billys68ss's Avatar
T-30??? Hmmmmmmm....... Thats a new one. What it most likely is is a 3/8 or 5/16 hex. But if it is a Torx it is more likely to be a T-45 or larger. Auto Library does not offer this information. Go figure. The best thing to do is to pull a wheel off and have a look. If you cant get in there with yer head. Get a compact mirror and have a look.
Hope this helps,
Billy
Old 08-08-03, 05:01 PM
If it has original caliper bolts it will be either 3/8 allen socket or a T500 torx.A t50 can be used in a pinch.
Old 08-08-03, 05:16 PM
Well it does mention something in the library about an allen bolt holding the caliper in, but, it doesn't say what size. Go figure. The reason I was asking is that I planned on bringing home some tools from work and I'd like to have the correct one to remove the caliper. I guess the best thing to do is to just bring all of my racks of allens and torx, then I'll have it covered I hope.
Old 08-08-03, 05:41 PM
billys68ss's Avatar
Toni..... Like Davo and I said, if its an Allen (hex) it is only 1 of 2 sizes. Either a 3/8 (most likely) or a 5/16. I use one that is a 3/8 socket so I can get leverage with my long 3/8 ratchet.
Billy
Old 08-08-03, 05:51 PM
darrell McCoy
Believe 3/8" allen.Pick up some disc brake grease, think permatex makes some in a squeeze bottle, about 6 bucks. lube the hardware a bit before re-installing, Check hardware for rust and corrosion, plus O rings. Use good quality pad to insure you dont have a squeaking problem down the line
Old 08-08-03, 06:14 PM
Joe_F
GM calipers haven't been allen in a while (My old rear drives are).
Many of the newer FWDs are Torx.
You're doing the right thing---borrow both racks/sets just in case, but you're going to find a Torx there I believe .
I think I paid under $25 for a Lisle Torx set at a swapmeet and it is USA made with T60 included .
Old 08-08-03, 06:18 PM
billys68ss's Avatar
Joe..... Direct from your favorite place..... Auto Library...
9. Remove the Allen head caliper mounting bolts.....
Billy
Old 08-08-03, 06:46 PM
Joe_F
GM parts book doesn't say for the Cavalier I have....some are, some aren't.
He's doing the right thing--bring both home .
Again, Sears has both sets of tools reasonably cheap---that's the route I'd go if I were starting out and didn't have them.
Old 08-10-03, 07:34 PM
Yea!!!!!!!!!! Success on the front brake job. Turns out you won the bet on the bolts Billy. It was a 3/8" Allen on the head. If I was a betting man, I would have guessed a metric Allen, but , I would have lost that one I guess. Anywho thanks for the moral support guys.
Old 08-10-03, 07:38 PM
darrell McCoy
chalk up one for toni on a job well done.
Old 08-10-03, 07:41 PM
billys68ss's Avatar
Glad you got it done and we could help ya out Toni.
Billy
Old 08-10-03, 08:18 PM
Joe_F
Good job
Old 08-10-03, 09:37 PM
Guest
Thumbs up
