Engine running rough
Old 08-09-03, 03:41 PM
rlodriguss's Avatar
I have a 76 Olds Cutlass Wagon 350 V8 with 110,000 miles on it. This car ran like a top. But lately I haven't used it much and when I do, it runs rough. One of my friends say it is a lifter, another says Carburator, yet another says fueld filter/pump. What do you think it is and how can I fix it??. I would like to get it running again so I can sell it. Thanks.
Old 08-09-03, 04:15 PM
darrell McCoy
need to try and determine, fuel or ign problem. May be as simple as new plugs and wires. Depends on how much $ you want to soak in it before selling it, I would start there. What speed is this occuring?.
Old 08-09-03, 04:26 PM
Joe_F
Assuming it's the original engine, it's an Oldsmobile 350.
They do break lifter rocker bridges and sometimes the lifters stick, but it's likely an old and tired carburetor or a vehicle in need of a tuneup/once over.
Tough to say what the problem is without knowing much about what has been done to it in the past.
Old 08-09-03, 06:22 PM
rlodriguss's Avatar
Iam sorry guys, I forgot to mention that I put in new Plugs, Ignition wires and Ignition booster in the
distributor. Also timed it. Still runs rough. I will remove the valve covers and see whats going on in there.
Thanks.
Old 08-09-03, 08:23 PM
Joe_F
Doubt it's in there.
I'd say carburetion---try some minor adjustments, and if there's no difference, likely in the carburetor.
