08-13-03, 02:04 PM
PPakrs1
blower motor will not shut off
My parents 1997 Concorde (3.5L) heater/A/C blower motor will not shut off. It keeps running in "high" mode, regardless if it is in "Auto" mode, or "manual" mode.
There seems to be a resistor block that the motor plugs into. There are 2 plugs in this block; one with 2 wires (Green and Black) and one plug with 3 wires (Black, Red w/ a yellow stripe, and Green).
If I pull out ANY one wire, the motor will shut off. I checked the resistance on the resistor block from the black wire (plug that has only 2 wires that come from the motor) to the other plug wires individually and had these results: black to black: .2ohms; black to red w/ yellow stripe: 7K ohms; and black to green: 61K ohms.
Looking at the autolibrary site, the wiring print shows 1 more wire and they are color coded different, but the run seems to match the series layout (if the resistance is correct) and now I am lost. PLEASE HELP!
Dean
Dean
08-13-03, 03:04 PM
PPakrs1
One more thing, I took out the control panel from the dash and unplugged it and the blower still operates.
Also, I see that on the autolibrary site, I was looking at the manual A/C, which is on the top left of the page and at the bottom right side of the print it shows the auto a/c and my wires match.
Any input will be greatly appreciated!
Dean
Dean
08-13-03, 04:43 PM
Joe_F
A stuck blower motor is a possibility (connections welded shut). Try rapping on it with a mallet and if it stops working/shuts off as it should, you've found your problem.
I recall that these cars eat up programmer/HVAC heads---common problem.
08-14-03, 10:13 AM
PPakrs1
I went to a local library and they have manuals made by "Mitchell" and it shows not only detailed wiring prints, but it also has a specific troubleshooting test (Test 20A) for the blower speed stuck in high mode. After going thru all the steps, using an multi-meter, it says to replace the ATC power module (resistor block). I had to purchase this item from the dealer, which cost $122.00. This made me extremely nervous due to the fact that this is a non-returnable part!
Well, I installed it and IT WORKS!! Problem gone...
Thanks guys for your help.
Dean
Dean
08-14-03, 10:40 AM
Joe_F
Score one for MSA, he nailed it down
Your post underscores the importance of having GOOD repair information and manuals!!!!
It's amazing what can be done with GOOD information!
