Accord turn signal help
Old 08-20-03, 06:22 AM
1mystik
Question Accord turn signal help
91 honda accord ex 4dr manual trnsmission
which fuse is for the turn signals in the fuse panel? If it doesn't have a fuse what besides the hazard relay controls the turn signals? I can't get mine to function I have a new switch and all!
Ok got new switch/ not the problem
Changed all the bulbs/ not the problem
got a new turn hazrd relay/ not the problem
I see the hazards have a fuse under the hood. Then wouldn't the turns have one also? In the manual it doesn't Identify it as haven't one. I will go thru all the fuses but I don't even know if they have the correct ratings to each one.
Old 08-20-03, 06:54 AM
Joe_F
Check your grounds closely. Good chance that there is a missing or broken ground somewhere.
As far as the turn signal relay/flasher, it MAY be integrated into a relay with another function.
Pull each fuse out one by one to eliminate them as being bad.
