Battery dies
Old 08-21-03, 10:40 AM
Battery dies
Hi there!
My corolla battery keeps dying if I leave it idle for more than 4-5 days. I thought that a new battery might fix it but no luck. I checked the alternator its fine. Also, checked with Toyota dealership on electrical discharge. According to them they cannot find any leak that is substantial, so a minor leak can be the cause but cannot find where. Does anyone know how I can figure out?
thanks in advance for your response.
-v
Old 08-21-03, 11:32 AM
tstokka
is the top of the battery clean? I've seen them where it was dirty and thats where the current was going.
How did they do the test? you need an ampmeter and hook it in series between the negative terminal and the negative cable. It should only read less than 1 amp. If more start pulling fuses and after each fuse check the meter if it changes then thats the curcuit to look at. It could be more than one curcuit.
Old 08-21-03, 01:16 PM
Joe_F
Thumbs up
Correct.
What year Corolla? Have you checked alldata.com for any bulletins that might pertain to the problem?
