fuel pump relay
Old 08-21-03, 12:44 PM
djoslyn
fuel pump relay
where is the fuel pump relay located on a 94 Chrysler Labaran, thanks, Dan
Old 08-21-03, 01:08 PM
Joe_F
Check autolibrary.org below.
What is the actual problem?
Old 08-21-03, 08:57 PM
mike from nj
under the hood, near the battery. i forget the transition year, you might have a power distribution center with nice labeled relays or maybe just a bunch of relays bolted to the inner fender near the battery( i don't know which one it is then).
if you want to purge the fuel system, you can just unplug the fuel pump at the fuel tank and let it run out that way, you will be under the car anyway. what i usually do at home is back onto a set of ramps and work that way---fuel filter is easier and fuel pump connector is right there too.
