Hard To Start
Hard To Start
I HAS A 86' HONDA ACCORD, HAS NOT START FOR LITTLE OVER A YEAR. I DECIDE START IT UP AND GET IT FOR SALE.
I HAD TO POUR LITTLE GAS INTO A CARBURETOR TO GET IT START
BUT IT WON'T HOLD THE IDLE, UNLESS I HOLD ON TO THE GAS AND CONSTANT POUR GAS TO THE CARBURETOR.
WHAT SHOULD I DO?
THE OLD GAS STILL ANY GOOD OR I NEED TO DRAIN THE OLD GAS OUT AND PUT NEW GAS IN?
ANY SUGGESTIONS WILL APPRECIATE.
WHAT SHOULD I DO?
Something else worth mentioning here is that if you are having to dump fuel into the carb while trying to keep it running, you could very easily have a fuel pump problem as well.
Hope this helps ya,
Billy
Hope this helps ya,
Billy
what i did found out yesterday (looks like there is no fuel flow in carburator):
disconnect fuel line (line to carburator), turn ignition and start
the engine, there is fuel flow thru the line.
reconnect fule line (lien to carburator), turn ignition and start
the engine, look inside carburator (with air cleaner cover off)
did not see any fuel flow thru caburator mouth.
the engine, place a fuel line on top of the carburator to let the
carb. soap up a little bit, then it started.
does this mean the caburator is gummed up on the inlet? carburator need service (rebuilt)?
any advise will be appreciate..
If you dump fuel into it and it runs, that's a carburetor problem. Likely gummed up.
These are not for the faint of heart to rebuild. They are quite hard to do and there's a zillion vacuum lines on them which are easily screwed up.
Sometimes you can get away with a top half rebuild, but all reality it will probably not run correctly or run well for very long.
Suggest it be professionally rebuilt for best results.
