A/C No Blow
Old 08-23-03, 07:59 PM
Lascelles
Unhappy A/C No Blow
I own an 87 chevy caprice. The A/C no longer blows but the compressor comes on. I replaced the Fan Motor relay but still
nothing. I believe the fan motor is bad.Is there anyway to test
the fan motor after removing it? Thanks for your help
Old 08-23-03, 08:11 PM
Joe_F
A possibility is a bad resistor.
If you bring direct power from the battery to the fan motor and it spins---look elsewhere, the problem would not be the blower motor.
Old 08-23-03, 10:46 PM
mike from nj
bring direct power AND GROUND to the motor connector.
most cars i work on(not chevy) have power on one terminal of the motor all the time, the ground side consists of the switch and the resistor.
