1990 Volvo 740
Old 08-24-03, 06:23 AM
wingnut325
Question 1990 Volvo 740
My 1990 Volvo 740 with 200K miles speedometer has quit. I removed the instrment cluster and checked all conections. I also removed the sending unit from the rear, cleaned the connections and the unit but no joy. Suggestions?
Old 08-24-03, 09:47 AM
Joe_F
Did you check the cluster for any damage on the circuit? Could have a bad speedo head.
Old 08-24-03, 01:27 PM
wingnut325
I looked it over real well and did not see any broken threads. Do you know how to test the pickup in the rear? What should the resistance be at room temp. Maybe that would give me a clue as to which component to go after first. Thanks for the reply.
Dave
Old 08-25-03, 03:55 AM
Joe_F
Volvo manual$ are quite expen$ive, so try an Alldata.com subscription for 25 bones to see if they have what you want.
Old 08-25-03, 10:24 AM
skim35
Check fuses?
Have check all the fuses?
Spedo is not one of component that goes out easy for these cars. Check the fuses & all connections first. Spedo converter has it's own fuse, located left-side under dash. It is known to blow out time to time when the car is improperly jumped.
